HOW TO TUNE A UKULELE9882154
2015年7月10日 (五) 06:43ElanorzzcurdtgufSamora讨论 | 贡献的版本
YOU WON’T SOUND GOOD UNLESS YOU TUNE YOUR UKULELE!
One of the most important matters to find out in the beginning is how to tune a ukulele.
Each string should be at exactly the right pitch perhaps playing won’t sound good. The easiest way to tune a ukulele, especially if you're just teaching yourself to play, is by using a clip-on electronic tuner (much like the Ukulology ukulele tuner).
Clip the tuner to your ukulele headstock, switch it on, and contain the ukulele inside playing position. The notes to tune the strings to are (counting through the 4th string, one nearest the ceiling) G, C, E and A.
Pluck the very first string, and view the display on the tuner. It has to show the letter A. If not, you must think about the musical alphabet (A by means of G, then repeat) and switch the tuning peg to either add to the pitch (tighten) or lower the pitch (loosen) on the string before the correct letter shows.
When you have the correct letter showing, you should tighten or loosen the string to really make the ‘needle’ point vertically to the top level of your display.
After you have one string in tune, repeat for the other three.
UKULELE STANDARD TUNING
What do we mean after we look at 'ukulele standard tuning’? Well, the most prevalent tuning or 'ukulele standard tuning' 's what we call C or C6 tuning (because open strings played together form a C6 chord). Some of the ways the ukulele is tuned to plain tuning:
The earliest string (the string nearest a floor in playing position) is tuned into a.
Your second string is tuned to E, a cheaper note compared to the 1st string.
The next string is tuned to C, below the 2nd string. This string is definitely the lowest note to the ukulele.
The 4th string is tuned to G. This string is nearly of up to the primary string! This means that the strings of the ukulele are usually not in pitch order. Instruments tuned in this way have been demonstrated to possess 're-entrant tuning'.
TIPS
- Examine your ukulele tuning each time you buy it to experiment with, or each and every time your ear notifys you something sounds ‘off’.
- Quite often you’ll only need to make small adjustments, so only turn the pegs a bit at any given time, and checking your tuner.
- If you use a digital tuner to tune a ukulele, it is going to only work when it can seem to be the vibrations with the string, so just remember to play a specific note and let it ring, whilst plucking the string when you examine your tuner.
Check out about how to tune a ukulele go to see this useful internet page
