CrystalStcyr708
2015年3月20日 (五) 12:36CrystalStcyr708讨论 | 贡献的版本
About The Product The Phantom two Vision+ from DJI brings prepared-to-fly into the professional realm. With its 3-axis gimbal supporting an all new custom 1080p video camera with Wi-Fi very first-individual-view (FPV) on your iOS or Android device, you will be making super smooth cinema-top quality videos in minutes. The Vision+ eliminates setup headaches with the gimbal and camera already securely mounted and aligned at the factory. It functions excellent, the footage is so skilled, it is remarkable and this issue practically flies itself with the GPS. Get more on this affiliated wiki by visiting Learn more at amazon.com/DJI-Phantom-Vision-Quadcopter-microSD/dp/B00PCTNVSC/DJI Phantom 2/. As a ready to fly unit, the quadcopter is hugely polished and performs properly, with no any sudden crashes or bugs. This quad is really straightforward to fly, virtually as well simple. I say this since an inexperienced flyer might rely too heavily on the GPS and other on-board sensors and might finish up in a bind if not prepared. The quadcopter flies fantastic and the very first individual view is fantastic and seeing bird\'s eye view of some remarkable things. Some essential features and advantages of DJI Phantom 2 Vision+ V3. Quadcopter • Super smooth video thanks to the 3-axis gimbal • Extra-extended flight occasions of up to 25 minutes from the intelligent 5,200-mAh battery • More flight power and security from the higher-efficiency self-tightening propellers, redesigned for V2. • This is V3. which includes an upgraded controller with rechargeable batteries and gimbal control dial, updated motors and much more effective propellers • Ready to fly The Phantom two Vision+ is basic to set up and super straightforward to fly, producing it the very first aerial filmmaking method for everybody. Now you can shoot totally stabilized video from the sky, proper out of the box. • 3-axis camera stabilization A built-in high precision 3-axis camera stabilization system brings a complete new level of smoothness to your aerials and provides you total inventive freedom in the sky. • High efficiency camera& parameter settings The Phantom 2 Vision+ carries an extremely high good quality camera and a 4GB micro SD card. It shoots complete HD video at 1080p 30/60i, 720p 60for clean slow motion and requires 14 megapixel stills. Camera settings can be adjusted via the vision app. • Improved Power New motors, propellers, and ESCs combine to give you higher thrust and handle than ever before. You can load more equipment on your Phantom, and attain up to 200g/axis of further thrust when using a 3S LiPo battery with this completely new program. Efficiency It is excellent when turning crucial solution for somebody looking for a really capable FPV drone. The Phantom two flies like a dream, even in moderate winds. It really is really straightforward to fly. The simplicity and responsiveness of the controls tends to make flying it fairly easy. The videos are crystal clear and the capacity to handle the camera from your phone or iPad is a huge plus, which includes the advantage of seeing all of the flight data on your phone/iPad. The camera quality is Medium-Very good. It records in 1080p at 30FPS, 1080i at 60FPS and 720p at 60FPS..
