KempfMascarenas732
2015年2月17日 (二) 07:51KempfMascarenas732(讨论 | 贡献)的版本
The BIOS wasnt able to find the hard drive. So I did some looking on the web and found a genuine crazy way to retrieve the data.... Here was a real life situation I was in. I worked as a support staff and one day a notebook that crashed was given to me. After some diagnostics, I discovered bad sectors on the hard disk drive and a great deal of clunging looks when I turned on the notebook. However, the consumer must have it in 24 hours and have some essential data to the hard disk drive. I discovered http://surfline.com/company/bios by browsing newspapers. The BIOS wasnt in a position to discover the hard drive. So I did some searching on the net and found a genuine crazy way to retrieve the information. Therefore, I made a decision to set it to the test because I've tried different ways to recover the info without success. I remove the hard-disk in the laptop and place in the fridge Today its important that you do not put the hard disk drive within the icebox for too long. I put it set for about half an hour and then quickly linked the hard disk to an additional hard disk casing and connected it to a different computer via the USB port. Remarkably, it worked, the hard disk was found and I copied the data the user needed for the computer as quickly as I could. I have done this a couple of times since then and it will worked. But, I found it will only benefit a brief period of time. This compelling purchase here wiki has a myriad of striking lessons for where to think over this enterprise. So you should copy as quickly as possible for your computer when the hard disk is working usually, you will have a period of about 15 to 20 minutes. Somehow cooling the heat of the hard drive helps a great deal. Heres another idea that I found. You can try tilting the hard drive sideways or at an about 60 degrees downwards. If you have an opinion about history, you will certainly need to compare about Project Wedding. I discovered that by doing this, I may increase the time by another 10 minutes or so. To compare more, please consider taking a gaze at like i said. But I prefer to caution you that only try this method when all other types of recovering the data fails. There is an opportunity when it is in the freezer for a long time the hard disk is permanently damaged. Also, this technique will only work if your hard disk is still spinning when driven up. If your hard disk does not spin and is useless in the water, then this technique will not work..
